Driver's seat.-.
ottoitis, Apr 12, 2:12pm
adjustment lever on Ford Fairmont '94 sedan doesn't shift forward to drop height. Please share your knowledge, thank you.
quickstitch, Apr 12, 2:42pm
some one has had it off and not put it on in the right position, they can be a bit of a mission to get right. is it pointing up at a 45 deg angle !.
ottoitis, Apr 12, 3:17pm
It is as you said, 45 degrees. I then pull it backwards and it moved, but won't shift forward!
tonyrockyhorror, Apr 13, 10:28am
Wow. Really muddled posts.
bellky, Apr 13, 10:33am
Isn't there a lever under the front of the seat to shift it forward!
tonyrockyhorror, Apr 13, 11:10am
ottoitis, Apr 13, 11:27am
Maybe I didn't make myself clear. Lever on right hand side driver's seat for high/low adjustment. Lever is now stuck on upright position. Can't shift lever forward to lower seat.
tonyrockyhorror, Apr 13, 11:33am
Remove the seat. It's only 4 bolts. Then you'll have access to the mechanism to see what's wrong.
tonyrockyhorror, Apr 13, 11:36am
Oh, and I think that lever is base tilt, not height.
bellky, Apr 13, 11:52am
I get you now. There is a little knob with a piture of a seat on it. You must pull that knob out to extend the arm and it also disengages the ratchet. Then you can lower the seat.
bellky, Apr 13, 12:16pm
Height.
ottoitis, Apr 13, 7:16pm
Yes, knob extends but cannot push it forward, suspect ratchet locking somewhere. Lever similar to post #13.
ottoitis, Apr 14, 6:38am
An update, lever now all ok. I pulled on lever, it extends, then stops, but, with an extra pressure in pulling it up again, it extends more for lever to be able to being pushed forward/backwards to raise/lower seat. Thank you all.
