do you want power or do you want ecconomy! power! stick with the DP n start tuning. Ecconomy! sell the pos & buy a 4 cylinder. :)
jason18,
Jun 20, 7:13pm
Hahha I want power! I not worried about economy.
cuda.340,
Jun 20, 7:49pm
that edelbrock is a good carb but it's not a HP carb. but you'd find it would probably work well on your combo. they're an air valve secondary, unlike a vac secondary, if the engine can't suck it, it don't open fully.
jason18,
Jun 20, 8:00pm
Ok Cheers. Thing is I dont know if I should go full on power or drivability. Im not going to race it etc but I do like my power. I just want a car to jump in and drive smooth but still have power when needed.
cuda.340,
Jun 21, 3:09pm
buy the edelbrock. at least theres no gaskets below the fuel line so no leaks.
quickstitch,
Jun 21, 3:11pm
i second edelbrock.
patiki1,
Jun 21, 6:23pm
Stay with the holley,but get it dyno tuned.
jason18,
Jun 21, 7:25pm
Willconvince the missus I need both and try em out for size.
cuda.340,
Jun 21, 9:31pm
when i got the 340 first running i had a850 thermoquad, was tricky to tune right, changed it for a holley 650 spreadbore dp. kinda good but didn't quite like slow traffic, changed it for an Edelbrock & bought a tuneup kit for it. experimented with it but came back to it's std setting. the Eddie was the most street mannered carb i had, you'd probably find the same. changed it for a Holley 750 dp, most power, best performance drank loads of gas in heavy traffic, but it went fast.
jason18,
Jun 22, 11:06am
Awesome thanks mate, Have decided to stay with the holley. Drove it this morning and damn its fun! Will tune her up and get rid of the stutter. I want this old girl to haul ass.
cuda.340,
Jun 22, 2:59pm
look at accerator pump settings to fix the stutter
jason18,
Jun 22, 7:08pm
Ok have been mucking around with them but havent got it any better. Is a 29 primary an ok size shooter or should it be larger! The secondary is 37.
patiki1,
Jun 22, 8:44pm
The primary butterfly must be adjusted so that a small portion of the transfer slot is below the throttle blade at idle so it appears as a "square".Then you need to set your idle mixture.A vacuum gauge or a wideband meter will help here.When you have that done you can set up your shooters and pump cams.You might have to change the jets too.
