Indicator flashing too fast
Page 4 / 5
hornnett, Jul 4, 3:16pm
Five people then gave you pretty well much the same answer what does that tell you!Bring in in as our crystal ball is in the shop for repairs.
This is the system that others use and it does work.
mugenb20b, Jul 4, 3:24pm
Do you have an anger problem!
hornnett, Jul 4, 3:26pm
Cant suffer fools problem
hornnett, Jul 4, 3:29pm
Have done that and guess what end up here again.
peekaboo4u2, Jul 4, 6:23pm
christinii.
hi as people have said bulbs etc.
If you cant get it sorted you can get a new flasher unit (relay) that is used to replace jap ones when changing to led light which causes hyper flash even though you haven't changed to led.
Like this one
http://ledstuff.co.nz/product_info.php!products_id=104&osCsid=ttusmauzfqfkq
Hope this helps
jason18, Jul 4, 7:24pm
Far out what a sh*t fight all over a bulb
kazbanz, Jul 4, 7:27pm
I'm wrong-cost to OP $5.00 and the ability to say to local sparkie -I tried xxxxxx
I'm rightTOTAL cost $5.00Pretty much a no brainer isn't it!
Ie the cost for me being wrong in offering a fix that will work TOTAL $5.00
Are you saying you WOULDN'T check the simple stuff first!
Hmm funny aftermarket indicator fitting in the front.---Maybee accident replacement with too low a wattage bulb.
Waith though -Fitting wont take a standard bulb
Need to raise total wattage so the overall wattage is the same as factory. Fit a bulb in another location with an equal increase in wattage.
But don't let logic get in the way of your diatribe aye.
kazbanz, Jul 4, 7:28pm
problem is just one side
supernova2, Jul 4, 7:37pm
If as some are saying upping the wattage will increase the flash and OP has said that the front bulb holder is not the correct unit could it be possible that some cowboy has worked on the wiring (just about anywhere on the circuit) and has created a partial short.Other option could be that if the front is a combined side light and blinker that its wired back to front.I'd have thought that front and back would be 21w (fronts could be 21/5w twin filaments) and the sides would be 5w.I agree swopping the bulbs from side to side is the easy way but as Op has said can't do that it really is becoming a job for someone with a multimeter and the knowlege to use it.
supernova2, Jul 4, 7:44pm
If my thinking is right the total wattage should be 47w.If as OP says she only has 31w she needs to add 16w to the circuit somehow.Surely if the front is only 5w the other problem would be that it will be too dim.
hornnett, Jul 4, 8:10pm
And if you have no idea what you are doing and cause even more damage what cost is that!My guess and this is just a rough one because i am not as knowledgeable as you is way more than what a decent professional would have charged in the first place.
But its only free information you are giving and no responsibilityon your behalf carry on.
"Pretty much a no brainer isn't it! "wonder how many times that has been said before a DUCK UP.
supernova2, Jul 4, 8:23pm
Geeessss hornnett lighten up for goodness sake.OPcame on here as far as i can tell asking if the MB could suggest a fix for her problem.Sure some of us on here engage in some borax poking from time to time but i fail to see what any of your postings in this thread have done apart from unwarrented attacks on fellow posters.OK maybe you think it better that the Op take the car and pay to have it fixed, if thats your opinion you are welcome to say that and then quite frankly keep quite after expressing your opinion.Others have suggested possible reasons and possible ways to overcome those reasons and thereby fix the problem.The only expensive damage that I can think of would be to burn the car to a chrisp.Unless the fuses have been bypassed thats not a very likely possability.Whilst the OP is not a rocket specialist I don't consider them to bea "dimbulb" (pun intended) either.The questions are lucid as are the responses.
hornnett, Jul 4, 8:44pm
Yea you are right the only damage would be the car burnt to the ground.So what happens when later on this same person wants to know how to fix their BRAKES,whats the worst that could happen eh.
tonyrockyhorror, Jul 4, 9:09pm
Apparently someone's crystal ball isn't in the shop after all.
supernova2, Jul 4, 9:16pm
They might break something perhaps!I'm sure we could quide them through doing a complete reline useing a pair of tweezers and a ball point pen.You underestimate the MB's members powers.LOL
kazbanz, Jul 5, 8:05am
Pull your head in.Go on explain how fitting a 10w rather than 5w bulb in an INDICATOR is going to cause major damage!
NOT ONCE have you said --NO that is not a possible cause of the problem.Nor have you said that it is not part of the diagnostic process to check the overall wattage of the bulbs.Instead you have replied with banal generalities.
The OP isn't asking to fix brakes they are asking for possible and simple solutions to a minor electrical issue.
modie61, Jul 5, 8:13am
Hornetts garage is called Agro Motors.Lol.
hornnett, Jul 5, 4:20pm
"The OP isn't asking to fix brakes they are asking for possible and simple solutions to a minor electrical issue."And yet the brains trust is still way of the mark.All automotive problem require thought not the guess and hope system of the uninformed.
Most garages should in fact up the charge out rates as we under valve ourselves,after reading how the rest of you go around fault finding.
ljack, Jul 5, 6:16pm
only my 2 cents,the bulbs cant be in series, cause if one was to blow the affected indicator side wont workas well as the first bulb will be the brightessed and the last dull.
hornnett, Jul 5, 6:28pm
HA HA HA HA HA sorry mate i just urinated myself with laughter.
ljack, Jul 5, 6:40pm
Im in the trade diesel and auto elec, work for a large trucking fleet company, always happy to hand out advice for FREE, if fact we do a lot of quick repairs on private (friends and friends of friends) owned cars at lunch times as long as owners supply partsand no cost to boss, and charge beers for the labour (keeps IRD happy)then have free piss up, boys love it.
hornnett, Jul 5, 7:02pm
"the bulbs cant be in series, cause if one was to blow the affected indicator side wont work as well as the first bulb will be the brightessed and the last dull."In the trade yea right.lol.FREE ADVICEgod surly nobody would be mad enough to pay for it.
ljack, Jul 5, 7:25pm
Yeah my bad was thinking ofa combination circuit, however cant be in series, always happy to pass free advise, hope we here, arent taking food of ya table, LMAO
hornnett, Jul 5, 7:30pm
Yea thats what i am worried about,finding it hard these days to make a decent living as the trademe motoring MB are fixing their own and others vehicles.
ljack, Jul 5, 7:36pm
true, but maybe cause alot of peoplefind it hard to find the cash for a tradie, god knows parts arent cheap (even with dicount) so most can only try to cut down on labour costs with the aid of MBs and google
