How to remove a seat from my Toyota Noah?
maccashore, Oct 31, 6:31pm
Hi there all - I want to remove one of the middle seats in my Toyota Liteace Noah and wondered if anyone knew how it is done. Supposed to be easy but I don't know where to start - can anyone assist! Many thanks - much appreciated. Roz
mugenb20b, Oct 31, 7:13pm
Do you have the owner's manual!
maccashore, Oct 31, 7:25pm
No - I don't have a manual.
maccashore, Nov 1, 5:17am
x1
Does anyone know how to do this!Cheers.
kazbanz, Jan 18, 10:08pm
macca.-It is indeed pretty easy.If its the 2 plus 1 configeration.then first fold the very back seats up so you have room.
Slide the middle row as far forward as it will go and you will see either grey plastic caps or 50mm squares where the carpet has been cut out
Remove these and you'll see the bolts. You need(from memory) a 14mm socket. to undoo the bolts.
slide the seats right back and repeat at the front.
They are now loose. Youll find the single seat by the door is fairly easy to lift out but the main seat is suprisingly heavy.
