Anti Freeze change
Page 1 / 3
kiwis, Nov 13, 6:31pm
Just drained radiator, do I put the full bottle of anti freeze in or is there a ratio of anti freeze to water! and yes I am a woman!
intrade, Nov 13, 6:34pm
depends on the car. Dont drive it unless you done it correct . normally you flush the system .
antifreeze comes as concentrated or premix.
and some new cars need special expensive long last like my bora diesel vw.
intrade, Nov 13, 6:36pm
car !
Make !
Model!
year!
and what antifreeze have you got will say so on bottle.!
kiwis, Nov 13, 6:42pm
Mitsy Galant 2001
The anti Freeze is RS200 based on ethylene Glycol! does that help, jeez I have already poured it into the radiator.
kiwis, Nov 13, 6:46pm
Can anyone offer some advice!
peril787b1, Nov 13, 6:52pm
What does the bottle say! On the back it will have a "mix to X ratio"
kiwis, Nov 13, 6:54pm
Longlife concentrate!, jeez Im not going to blow my motor up am I! I just filled the whole radiator up and then put hose in the very top, also poured some in the overflow tank as well.omg what have I done!
kiwis, Nov 13, 6:56pm
Doesnt say anything about mix to x ratio I had a good read.
dent, Nov 13, 6:59pm
how big was the bottle
what colour was the antifrezze in the bottle and wat colour was the fluid already in the radiator befor you drained it!
kiwis, Nov 13, 7:00pm
Big, like 3.57 litres.
The fluid was green before and is blue now.
dent, Nov 13, 7:01pm
what colour was in the bottle!
kiwis, Nov 13, 7:02pm
The stuff in the bottle was blue!
dent, Nov 13, 7:05pm
some antifrezze you cant mix you better check to see if it says on the bottle somewhere. Compatible with all other antifrezzes.
kiwis, Nov 13, 7:06pm
I didnt mix the old with the new,I drained the radiator completelyfirst and filled it with the new blue antifreeze concentrate now Im scared it might blow my motor up.
intrade, Nov 13, 7:10pm
na it wont blow up. You drained the radiator but thats only 40% of the whole system. if its competabile with other antifreeze then it be okYou got to check if its got a overflow bowl from radiator . and post the full brand of the antifreeze i only know green stuff and red longlive my self lol.
unbeatabull, Nov 13, 7:10pm
There would still be old coolant in the engine block, draining out the bottom doesn't get rid of all of it, usually only about half of the total volume.
From memory blue/green are both Inorganic times, whilst Orange/Red/Pink etc are all the HOAT types. You can't mix Inorganic and HOAT. Green and blue should be fine.
From memory blue/green are both Inorganic types, whilst Orange/Red/Pink etc are all the HOAT types. You can't mix Inorganic and HOAT. Green and blue should be fine.
kiwis, Nov 13, 7:14pm
This is what its called on the Label:RS200 based on ethylene Glycol
intrade, Nov 13, 7:15pm
yea it was concentrated so it refreshed the remaining stuff up again , not the correct way but will work. Just make sure cap has not a brittle rubber and is closed correct and overflow bottle also is filled to max if it has overflow conection then recheck overflow after a drive dont ever open radiator when hot in case you dont know that already.
intrade, Nov 13, 7:16pm
etylene glycol is the green stuff as unbeatabull said being a mitsi it probably had non expensive other antifreeze in there before.
kiwis, Nov 13, 7:17pm
What sort of things will go wrong if its too concentrate! I am worried now.dont think I will try any more smart ideas!
intrade, Nov 13, 7:21pm
well it would have to be only concentrated the whole system to cause a problem. and you only done 40% at best as the engine and heater in the car holds loads more coolant . So it be fineand another problem you dont have because you only drained the radiatoris it wont have air in the system
kiwis, Nov 13, 7:22pm
Thanks for your input intrade, I really am sweating about my stupidity!
