Dodge ram
fordjay, Dec 15, 10:47am
hi i have a 98 dodge ram and it has started smoking white smoke to the point of not being able to see behind me. water level is okay oil is good brake fluid is good as well! please and advise as i need it to tow my caravan thanks
intrade, Dec 15, 10:49am
diesel!
fordjay, Dec 15, 11:07am
no it is petrol sorry
berg, Dec 15, 12:00pm
White smoke or blue tinge! Maybe faulty PCV valve or similar. Other possibility could be some bodies filled the exhaust with water.
fordjay, Dec 15, 12:29pm
90% white with the odd bluey tinge
will check PVC valve thanks
philltauranga, Dec 15, 12:33pm
Id get a compression test to see if its piston rings, otherwise i would think valve guide seals for that ammount of somke tho I would guesspiston rings.
rod-zone, Dec 15, 12:53pm
Is there any vacume lines from the trans to the intake! there could be a "stuffed" vacume modulator and could be sucking trans fluid
Usually being white i would point to the brake fluid but if the levels are good then its not that
pfemstn, Dec 15, 4:07pm
has some one put diesel in the tank!
attitudedesignz, Dec 15, 4:12pm
My guess.
petermcg, Dec 16, 5:03pm
I think this could be the right answer
trogedon, Dec 16, 8:03pm
There are wreckers who take commercial vehicles.
fordjay, Dec 26, 7:03am
thanks guys we have got it all fixed and it running sweet as ever
berg, Dec 26, 7:05am
What was it!
chevcamaro, Dec 26, 5:58pm
come on what was it, nut behind the wheel, a screw loose, somebody ate all the strawberrys, santa dia it what was it !
