Have a friend who is looking for a ute. Requirements are double cab, diesel, doesn't need to be 4wd, to 2wd is fine. Wants something taller rather than lower Budget of $15k.
What would be some good options, or models to avoid in this range?
What are
tygertung,
Oct 18, 5:04am
I truly believe that a station wagon and a trailer is going to be a lot better than a ute. Not only do you have much more load capacity, you can leave the trailer at home when you don't need it and the stuff in the back of the wagon will keep dry.
