Can the 2 stroke oil for a motorbike be used in a boat motor as well!
bellky,
Oct 3, 2:35pm
air cooled engine 2 str has an ash content to keep engine cooler - water cooled does not have this. that's the diff afaik
vix.tribe,
Oct 3, 2:48pm
Ahh, thank you.
While I'm on a roll asking stupid questions. how long does the fuel and oil mix last!For a motoX bike, if you mixed up a tank of 98 petrol and oil, how long till it wasn't really a good idea to use it!
bellky,
Oct 3, 2:50pm
my experience is with stihl and it lasts for extended periods - like 6 mnths 12 mnths no problem, doesn't even seem to seperate.
vix.tribe,
Oct 3, 2:52pm
Sweet!Cheers for that.
bellky,
Oct 3, 2:55pm
no worries - i store it in a cool dark place, don't know if that makes a difference but makes logical sense to me
bellky,
Oct 3, 2:59pm
ok to answer your question (all care no responsibilty here mind you) if you have some air cooled 2 str oil you don't want to waste, you can use it in your outboard motor (water cooled i presume) i would say, without damage. the amount of ash is very minimal and only builds up over time
i wait for someone to disagree.
vix.tribe,
Oct 3, 3:12pm
And sounds safer if nothing else! ;-)
The bike will be ridden at the very least once a month, so can't imagine fuel sitting round for more than a couple of weeks.Good to know we don't have to buy fresh fuel every time he rides, thought it sounded a little pedantic.
steve312,
Oct 3, 3:17pm
Petrol does deteriorate as soon as you add oil to it.I don't use old pre-mix in my MX bike.Anything over 3 weeks old gets used in the mower and a new batch is mixed up for the bike.
bellky,
Oct 3, 3:18pm
i wouldn't recommend using water cooled engine 2 str in an air cooled engine though. the ash content is important to keep engine cool.
vix.tribe,
Oct 3, 3:20pm
What happens to it as it deteriorates - what would happen to the bike engine!
bellky,
Oct 3, 3:21pm
what's that mean!
vix.tribe,
Oct 3, 3:21pm
Definitely won't be going that way. :-)
vix.tribe,
Oct 3, 3:23pm
It's a fullstop and a face I *really* wish I could actually pull! lol
maz61,
Oct 3, 3:26pm
it means, WTF! you do not put shitting chainsaw two stroke oil in ya water cooled outboard
vix.tribe,
Oct 3, 3:29pm
Or can I put it in there and just not tell Himself! ;-)
steve312,
Oct 3, 3:49pm
Have seen a few bikes run lean and melt a hole in the piston on too many occasions for me to want to have the same problem.Far easier to mix up a new batch each time I have a race meeting. Originally worked on small 2 stroke engines when I first left school and the advice from many of the suppliers was to use fresh fuel in their products.Same advice when I attended service schools and repair courses.
I definitely wouldn't use 2 stroke oil for anything other than what it is designed and blended for.Why risk an expensive rebuild when it is easy to have a couple of seperate containers for motorbike and outboard fuel.
vix.tribe,
Oct 3, 3:59pm
Thanks, I appreciate your time.Certainly don't want to be risking the bike engine for the sake of a few dollars. If it's only two weeks between race meets, and there'sa couple of litres of fuel mixed up from the last race, would it be risky to top it up with fresh mix!What about what's already in the fuel tank, do you drain it between meetings!
bellky,
Oct 3, 4:03pm
why not i use it my car
oliver6,
Dec 6, 1:16am
I use oli which has been premixed for months, sometimes 6 months. The petrol goes off a bit in the carb', so if a bike hasn't been started for a few weeks, I drain the carb', but then start the bike and run it with the old mix which has been in the tank, sometimes for 1 year.
