My back seat belt is sticking and wont retract until i pull the panel off and manually wind it back.
After I do that its fine for a few weeks, before sticking again.
Do i need to replace it all together! or is this something the mechanic can adjust!
Thanks
Jan 19, 9:09am
before you do that I would go out of my way to clean and degrease the belt and ANYTHING it touches. (except the actual reel)
mechnificent,
Jan 19, 9:51am
Yup, pull it right out and give it a good clean.
opencast,
Jan 6, 3:42am
Be sure to clean any build up on the top loop,you may find a patch of sticky goo on the underside of the loop where the belt runs, clean it and then pull the belt right out and Lube the webbing I use silicon spray, and spray the belt then work it a few times.
Pretty much as above.
