Why would a car overheat when it has water and the radiator is full fan belt fine and thermostat is new!
motorway,
Dec 28, 6:45pm
Make /model!
gadgit3,
Dec 28, 6:46pm
Blocked radiator core. Internally or externally Water pump vains damaged or missing Air lock in cooling system Theres a few
Dec 28, 6:47pm
Blocked radiator (internally), fans not going, stuffed water pump, etc.
afer_daily,
Dec 28, 6:47pm
blocked radiator tubes / could need a flush .
van78,
Dec 28, 6:48pm
Mitsubishichariot
Dec 28, 6:56pm
1. Are the fans kicking in and out! 2. Are all the water hoses hot (top, bottom and heater)!
van78,
Dec 28, 7:02pm
yeah the fans are going, hoses are hot and no the heater doesn't go
morrisman1,
Dec 28, 7:03pm
take the belt off the water pump and see if it has a bad bearing. On our stellar which has the same engine I think it had a crook bearing and that meant that the angle of the impeller was such that the water stopped pumping.
van78,
Dec 28, 7:05pm
Thanks Morrisman1 will give that a try
Dec 28, 7:06pm
1. Was there any signs of rust or corrosion in the coolant when you changed the thermostat! 2. When the fans kick in and out, does the whole radiator core feel hot!
van78,
Dec 28, 7:11pm
the water was red so thinking that may be a sign of rust! yes the whole radiator feels hot
msigg,
Dec 28, 7:30pm
circulation no good why is the heater not going! thermostat shut stuck ! blocked raidiator, water pump
jenny188,
Dec 28, 7:31pm
Blown head gasket or worn ringsas well as any or all of the above, cracked head, or if getting close to 250,000 kilometers just worn out.
next-to-normal,
Dec 28, 10:11pm
change your radiator cap,look at your oil filler cap, on the underneath side for water in oil,test your themostat, or leave it out.,use antifreeze to raise the boiling temp,use motorup in oil too,but most important, is there strong circulation of water movement in the raidator,as the water pump could be issue, but dodgy raidtor cap could slip under the rader, and right pressure, and dodgy workshops play silly buggers with cars too
Dec 29, 10:21am
^^^^^^^^^^ OP, please ignore these comments.
gadgit3,
Dec 29, 10:43am
Agreed^^. Leaving out the thermostat can cause alot more overheat issues with a bypass type system. Motorup is a complete waist of money
richard198,
Dec 29, 5:24pm
How do you know/think it is overheating! You haven't given any symptoms yet!
johnf_456,
Dec 29, 5:26pm
I agree totally
