Filled car with 91 octane and now not going
kym70, Jan 5, 9:12am
friend has filled their car with 91 octane and it normally runs on 95 octane.now car doesnt want to go.any easy solutions !
trdbzr, Jan 5, 9:15am
What car is it! I very highly doubt putting 91 octane into any car would make it stop going. Most likely something else is going wrong.
kym70, Jan 5, 9:17am
its 2.5 v 6 telstar.early 90s i think
singing1, Jan 5, 9:21am
Did you put air in the tyres too!
Because that could do it.
kym70, Jan 5, 9:29am
always one funny fella aye!
motorway, Jan 5, 9:35am
It will be something else.sure it wasn't diesel!
m16d, Jan 5, 9:37am
Maybe there's air in the tank.!
lyonruge, Jan 5, 9:40am
91 wont make it not go, but diesel will.
franc123, Jan 5, 10:02am
The adding of fresh clean 91 won't have caused a no start problem, something else has gone wrong.In fact the only common things that really stopped that model from going was broken cambelts of course, and coils/ignition modules failing which basically means a new distributor is needed.Get the usual checks for spark and fuel delivery done.
kazbanz, Jan 5, 10:23am
KYM--You really aren't helping. Can you PLEASE describe the sequence of events. As it sounds right now you freind pulled into a petrol station and filled up and it wouldn't start straight away afterwards.
nave12, Jan 5, 10:30am
Fuel pump could have even conked out,heard that before after some one has pulled up at a servo filled the tank and then no go.
lasertech, Jan 5, 1:07pm
Common issue is the ignition modules
granada, Jan 5, 2:15pm
it wont be that because they filled it up with petrol, It would have pushed all the air out of the filler pipe
richard198, Jan 5, 2:19pm
Sounds like a coincidence to me.
ginga4lyfe, Jan 5, 3:12pm
+1 that
and I have NEVER seen a diesel v6 telstar, you would have had to drive a little while to get the old petrol out the lines, so it would have conked out later on outside of the servo. but speculation is just that. speculation, we Do need details.
marte, Jan 5, 4:58pm
Does anybody put Acetone in their petrol to improve it!
Only needs 30mls for a tankfull, I don't think it would ruin anything.
I did it by accident with my dirtbike & it made a great difference.
thewomble1, Jan 6, 12:27am
Vapour lock in the fuel line from a hot motor. Filled car with diesel and trying to start has been enough for diesel to be sucked into the fuel lines etc.
big.b-lil.c, Aug 13, 8:50pm
the easiest solution is call a mobile mechanic. have a nice cup of tea while he fix's the car.
