Fixing indicator on scooter
kazbanz, Jan 7, 10:30am
The two problems may be related or may actually be unrelated.
The generic answer is.
1) unscrew/unclip/pop out orange cover
2) remove bulb
3) if you have access to compressed air dry the bulb holder with air. If not dry it with a rag as well as the lens/lens holder. Another option is to spray contact cleaner in there
4) lightly sand the inside surface of the bulb holder with fine sandpaper and try to sand the contact in the bottom of the bulb holder.
5)fit it back together
millna, Jan 7, 10:33am
i think it is unrelated. the blubs were all blowing except the faulty indicator. when i used the throttle. now i can use the throttle with no bulb issues. i will give it a good clean and dry. thanks.
millna, Jan 7, 10:56am
cleaned and dried. but still no go, I will investigate further
kazbanz, Jan 7, 11:00am
swap bulbs left to right. if the problem swaps the bulb is the issue if not then look deeper. att he back of the bulb holder will be two wires. trace them back and make sure they are unbroken and plugged in propperly
millna, Jan 7, 12:20pm
the wires all look attached. i have given a fairly good dry but still no luck.
millna, Jan 7, 1:11pm
pulled it apart and put it back together.still no light
jmma, Jan 7, 1:36pm
Do you have a test light!
ceebee2, Jan 7, 2:13pm
Does the front flash as well!
millna, Jan 7, 2:46pm
no test light. all other lights work okay.
jmma, Jan 7, 3:02pm
May I suggest that you go buy one, It will make the job so much easier, they aren't that dear either.
millna, Jan 7, 4:25pm
will do :)
kazbanz, Jan 7, 4:29pm
did you swap bulbs left to right etc!
millna, Jan 7, 4:44pm
yip :)
millna, Jan 7, 7:58pm
left front turns on but does not flash. the other side (the right works fine) Headlight and brake work as well and function as they should.
jono2912, Jan 7, 11:50pm
Do you know where the flasher unit is!
millna, Jan 8, 7:13am
i think it is under the seat
millna, Aug 24, 4:45am
all fixed. it had no earth.
