Phillip.Weston a question for you please. Hey phillip i39ve just noticed my st r legnum is leaking transmission fluid from the b
willz29, Jan 9, 10:28am
Hey Phillip, I've just noticed my ST-R Legnum is leaking transmission fluid from the bottom of the transmission. The last WOF I had I noticed the mechanic tightening up the bolts so I guess its probably the gasket. Is it safe to use a transmission stop leak additive! I only had the rocker cover gaskets replaced in December and really can't afford another repair bill.
alan1111, Aug 27, 1:11am
Yes it would be safe as long as its transmission stop leak.But it wont fix the problem as those stop leaks only really soften seals to help minimise leaks.It will always leak until properly fixed.
