96 civic with cvt transmission
hob2, Sep 10, 11:58am
hi all, replaced start clutch and solenoids as well as new at trans computer.
car still shudders at take off and all of a suddenloses drive when over 60 kms the transmission d light starts flashing on the dash switch engine off and restart it will drive again no problem.,does the computer need to be reset or relearnt calibration !many thanks
crzyhrse, Sep 10, 12:05pm
So it's no different to what it was before the work!
You didn't find the fault definitively. Sounds speed sensor related to be honest.
hob2, Sep 10, 1:11pm
hi yes its better than before definitely but just that shudder is still there
and i think the computer may need reseting or relearn !cheers
luke041, Sep 10, 2:16pm
If the D light flashes it has set a code. You need to find out what the code is first.
hob2, Oct 19, 4:54am
ok cool .many thanks for your cnotributions. cheers
