Occasionally idles real low when engine is cold, and will sometimes die if you put it into drive straight after starting it up! once its warm it fine,
jasongroves,
May 31, 7:58pm
I would be looking for a vacuum leak and also removing the throttle body and giving it a good clean out.
dasfi,
May 31, 8:00pm
Iv heard its a pretty common problem for these things after talking to a few people!
May 31, 9:06pm
SR18 or 20DE!Idle control valves sieze and die on those things, they are under the intake manifold on the drivers side, usually they get stuck shut and you don't get a fast idle when cold.
wizid,
Jun 1, 1:18pm
thats the frist time i have heard of that . i have had 3.check what jason said . he is on the rite track
jasongroves,
Jun 1, 1:56pm
I not saying ignore my advice.but I would be inclined to listen to Franc (he does know a fair bit more than me).
dasfi,
Jun 1, 4:29pm
Yep sr20, Heard it was something along those lines, ill try cleaning it or see what i can do ,Cheers now i know where it is
Apr 27, 3:56am
Well you've heard of it now.
