Identify old electric horn
budgel, May 25, 11:51am
Looks like something from a flathead Ford. Were they six volt!
pfemstn, May 25, 2:58pm
chev 1930,s
tmenz, May 25, 3:07pm
I think it may have been the one that Gabriel originally blew.
mk3zephyr, May 25, 3:12pm
Or little boy blue, in which case it would be off a Ford lol
mrfxit, May 25, 3:16pm
LOL thanks but no idea.
Remember seeing something like that on the old railcars but can't find any pic's
mrfxit, May 25, 6:31pm
Thanks for the pointer, spotted this on the way around the net after checking out your link .
http://cgi.ebay.com/ebaymotors/T-A-SPARTON-WORKING-6-VOLT-14-1-2-LONG-HORN-/200609002910!pt=Vintage_Car_Truck_Parts_Accessories&hash=item2eb53a759e
Now to define the year it was made.
Next after that is to sort out a 12v to 6v stepdown.
jrlaw, May 25, 7:07pm
Not a Ford car horn, none I have seem anyway. Try it on six volts and see how it hoots. Feel it will be a six volt one.
mrfxit, May 26, 8:01am
Of to Jaycar later this week.
Guys there want to test it for amp draw & work out what it's REALLY doing for amps/volts etc.
tmenz, May 26, 8:24am
It will probably draw quite a lot of current - many amps!
Are you able to measure the static resistance with a multimeter - this will give some idea of the peak current draw!
mrfxit, May 30, 8:43am
Amp draw (without power attached) at jaycar peaked at 33 & settled down to about 11 / 13 amps, so would presume something like 10 to 20 amps draw.
Who's got an idea on what to use to drop 12V to 6V with a max 20 amp draw
intrade, May 30, 8:52am
it be a old foog horn . did you get it to work!
i found the same horn 6 volt in a old boat and the shape and noise it makes is for foog Drooooootttttt sound
mrfxit, Apr 18, 12:08am
What about using an old ign coil ballast resister, 1 of those ceramic 1's like you find on the 70's Valiants. (6V coil/ 12V supply)
Would that do the trick, bearing in mind that it's only for short bursts
