I have a 2005 Holden Astra
tweetysmum, May 12, 3:17pm
and the electronic engine management system light keeps coming on. In the manual it saysa system service is required.Can anyone out there let me know what this means and how important is this.( I have recently had my car serviced)
bubbles52, May 12, 3:24pm
Probably needs to be reset, see holden
jasongroves, May 12, 3:31pm
Which specific model/engine!
tweetysmum, May 12, 4:22pm
All I know is it isa 1800 cc
jasongroves, May 12, 4:37pm
Try holding down the button to the right of the speedo, turn the ignition to ON, hold the button down until the service indicator goes blank.
jasongroves, May 12, 4:39pm
If that doesn't work, then yours could be this model:
http://img196.imageshack.us/img196/9760/astra1pc.jpg
jasongroves, May 12, 4:41pm
Unless its a malfunction lamp, not a service light.if that's the case, you will need to go to a dealer or auto sparky to get the fault codes read.
http://img17.imageshack.us/img17/9594/astra2o.jpg
bigfatmat1, May 12, 6:05pm
It means
a: you have a problem with your engine and a sensor has detected the fault.
b: a sensor(s) has failed
astras are plagued with electrical problems best bet is to take it to a auto sparky. crank and cam sensors are the most common failure.
tweetysmum, May 12, 7:13pm
I noticed the gauge that tells you the temperature outside stopped working about a month ago,I didnt think it was a big deal.
Holden Dealership/service repairs etc are 5 mins away so I may pop in there.
carmedic, May 12, 7:38pm
EGR valve problems are by far the most prevalent on late Astras defiantly followed by cam and crank sensors as Mat says.
It??
c.franklin, Feb 13, 12:08am
This is usually a faulty crank or cam sensor - very common fault with Astra and Vectra's. Need to go to a Holden dealer and have it checked with diagnostic tester.
