Car over revving.
butter8, Mar 21, 4:56pm
Why would my car be over revving. Its an auto matic Mazda Demio. 1996. Only in first gear as well. any idea's.!
shortkiwiboy, Mar 21, 5:01pm
try putting the gear shift in 2 or D and not 1
butter8, Mar 21, 5:02pm
Its in Drive. I ment. When its going from first to second gear. or what ever auto's have.
dasfi, Mar 21, 5:13pm
trans sounds like its buggered,
butter8, Mar 21, 5:18pm
if it was low in trans fluid, could it cause over revving.!
dasfi, Mar 21, 5:24pm
wouldnt think do, remember to check fluid level with engine running and trans in park
butter8, Mar 21, 5:27pm
ok. thanks. so is a new trans going to cost alot.!
dasfi, Mar 21, 5:42pm
depends on the year!
butter8, Mar 21, 5:42pm
1996
dasfi, Mar 21, 5:48pm
See your in Upper Hutt, Try taking it to Mendoza Mechanical down goodshed road,
always get great service there, they could offer a solution or have a look for you
gtrmotorsport, Mar 21, 7:00pm
when was the last time you serviced your transmission ! i would say get it serviced and go from there.
74nova, Mar 21, 7:07pm
check the fluid level first.
scousemouse, Aug 11, 10:40pm
could be the second gear transmission band,pretty sure they can just drop the pump and check it for you.
