Motorcycle hard to start after running
dr.doolittle, Mar 18, 7:36pm
Air leak between the carb & head! What model & cc!
ezekiel67, Mar 18, 7:53pm
Try seaching on www.kiwibiker.co.nz
If you can't find anything ask on the boards.
ginga4lyfe, Mar 18, 8:09pm
maybe there is either too much heat in the carbs causing poor fuel feed, or not enough air getting in, or maybe. the mixture is slightly lean! when last did you service the bike! New air filter and plugs can make all the difference!
i-n-horz, Aug 1, 10:10pm
Yep, service the air cleaner and plugs then see how ya go.
