How to stick down car trim.
sue193, Feb 3, 8:37am
Hi could someone please tell me the best way to stick this down. I've bought a car and a bit of the trim has popped up. The man I bought it off said that he had stuck it down several times with something he got for the job but it kept popping up after a while. Whatever he used was black and lumpy looking so I would probably have to remove the remains of that as well. Thanks Sue
unbeatabull, Feb 3, 8:38am
Urethane.
sue193, Feb 3, 8:39am
Where can I buy that from!
intrade, Feb 3, 8:43am
are we talking on windscreen frame trim or what'
the-lada-dude, Feb 3, 8:44am
you would be hard pushed to go past a nail & hammer
unbeatabull, Feb 3, 8:48am
Anything exterior we use Urethane at work, it takes a bit of time to set but once its set that's it. It can be a little messy and doesn't come off once set so make sure you wipe any excess off before it sets.
Interior, we usually use Double sided tape or Q-Bond/Loctite Super Glue. All should be able to be purchased from Supercheap, Repco etc
sue193, Feb 3, 8:49am
i mean the silver trim that goes around the outside of the car. Haha lada man that's probably what my husband would expect me to use but no I'm going to get great advice off TM and fix it "properly"
sue193, Feb 3, 8:50am
Thanks unbeatabull
the-lada-dude, Feb 3, 8:53am
hey sue 193,
works on the ol lada !mind you, you have to smack the shit outa the nails because the steel is pretty thick on these cars.
pup2, Feb 3, 9:38am
lol must be the top end Lada to have trim on it
the-lada-dude, Feb 3, 11:38am
chrome grill,
i-n-horz, Feb 3, 10:28pm
OP,there's a tape you can buy which is like a double sided thin foam.peel one side stick it to the back side of the trim then trim off excess,when done peel off the protective film and stick'er down.
Probably need to clean off the old adhesive first though.
kokako14, Feb 3, 10:30pm
Thats the model with the heated rear window isn't it, to keep your hands warm when you push it home on a cold night!
thewomble1, Dec 5, 4:54pm
plastic nails if you don't want to see the nails.
