in my premio 96.trouble removing it cant locate the bolts holdin it in there .
dent,
Apr 6, 3:18pm
It will be bolted in through each leg of the fuse. There will be side covers on the fuse box you will need to remove to access the 6mm bolts.
gadgit3,
Apr 6, 3:18pm
You need to remove the fuse box and flip it.semi dismantle the top from the bottom then you will see the bolts you need.
wasser61,
Apr 6, 7:49pm
And then find out why it blew, before you replace it
Apr 7, 6:31am
bolts are on side you most times have to slide the whole plastic cover off and they are 10mm screw heads. You also undo the battery minus first before you start messing on there, and do as post 4 said also these fuses are expensive to buy .I would guess its a diesel glowplug fuse!
bigfatmat1,
Apr 7, 8:43am
100amp engine main jump started car backwards blew fuse! bolted in dissasemble fuse box to unbolt
jo458,
Apr 7, 7:31pm
thank you everybody that posted
