RWD P10 primera?
reggienz, May 9, 11:20am
Friends son has a rear wheel drive primera. Iv'e never hear of one before. Would it be standard or would it be a 4wd with no front diff and another gear box! Be keen to hear your views. Also, it has a north south motor.
hopie, May 9, 11:25am
Primera's all came out 4WD or FWD. so to be RWD they have either taken out the front CVs and welded up the diff, or fitted a north south SR20 into a 4WD shell (as the FWD does not have the tunnel for the driveshaft.)
BUT you say North/south, then im not to sure because AFAIK fitting a SR20 in that way needs firewall modifactions as the dizzy hits it.
andrea_w, May 9, 11:25am
It will be a converted 4wd model
1ollie, May 9, 11:27am
Yea as andrea_w said ^!Very common with EVO's and WRX's also
nightboss, May 9, 11:30am
From Wikipedia
"A rare AWD option was available known as a T4 with 150 bhp (112 kW; 152 PS)."
hopie, May 9, 11:45am
the T4 is the 4WD option.
a.woodrow, May 9, 11:48am
4wd and awd is the same thing
martin11, May 9, 11:51am
Sounds like its an oddball sure it a primera !
petemun, May 9, 11:53am
like othes have said - many people are converting from 4wd to rwd. not odd these days
edit: ahh he says north south motor. yeah you sure its a primera lol
richardmayes, May 9, 11:55am
If it has a North-South motor then it sounds like it's probably been modified to run a Silvia engine & gearbox, and either a Silvia or else a 4wd Primera back axle.!
(Could be quite a nice car if it's been done right. hardly seems worth the effort and expense though.!)
petemun, May 9, 11:56am
photos would be nice
modie61, May 9, 12:52pm
Maybe its an Almera !
