Actually a bit of a rant, today I was carrying a lawnmower in the back of it when some tardhat pulled out in front of me. Jammed on the picks, landed up getting hit in the back of the head with the lawnmower and sideways on the roundabout. Was quite mad.
whqqsh,
May 19, 4:16am
had the same with my mig welder, loaned to a workmate (happy to pick up from home when he needed it but only returned it to work), driving home, had to jump on the brakes, welder goes over & smashed the gauges, havent checked other damage yet. thats the last time, my stuff always come home worse than it left. no good deed goes unpunished
quickstitch,
May 19, 6:35am
similar story, had 3 cleveland motors and a falcon 9" on a trailer. not tied down as i was just going 5 minutes up the road to wash world to waterblast them. left washworld heading towards busy greenlane intersection and some asian decides to change lanes and cut me off, i hit the brakes and one of the cleveland long motor (no carb or dissy) slides/rolls forward, pops the front tailgate board out, rolls off the drawbar onto the road.Panic starts to set in, I don't need a ticket for unsecure load, A big island guy stops and we lifted it back on the trailer in one go. and those donks are bloody heavy, must have been an adrenalin rush, couldn't lift one of those again if i tried
jason18,
May 19, 6:36am
Mmm thats nice. Always wanted one of these skylines.
whqqsh,
May 19, 6:46am
if youve got anything decent Id seriously consider photoshopping your number plate out before posting anywhere but especially on here
cuda.340,
May 19, 6:46am
hey Jason, did you fix your off idle stumble! i see you have a single plane intake manifold, they're a common cause of the stumble you described.
quickstitch,
May 19, 6:55am
got my car back on the road yesterday. still need a few little things sorted out. like the timing. No markings on the balancer, its been painted to many times, Thought about starting motor up and getting under neath it with some sandpaper to clean it up but it is easy to go buy a new SFI approved balancer, as im stock piling goodies for to build a strong 351 or 393 motor. And im suspect about the dizzy, or maybe a stretched timing chain. I will go get some 98 octane gas in it today and try again. When i enquires on here about the procomp dizzy someone said they couldn't get consistant timing on theirs and junked it in the end. I normally can get the timing pretty spot on without a timing light
quickstitch,
May 19, 7:02am
Cuda , i've got the same slight stumble off idle at the moment, i'm using my 750 edelbrock that i bought for the good motor, it may be just a bit to much for the stock motor, and im using a single plain manifold, but i will play around with the timing first then start tuning the carb. i usually just stick the 500 edelbrocks on stock 351s, and they are fine
clark20,
May 19, 9:08am
Even tho I own a Holden, I do like that. The ford/holden thing doesn't worry me.
cuda.340,
May 19, 10:53am
thoses Eddie carbs are air valve secondaries so if it can't suck that much it doesn't use all the carb BUT single plane minifolds are shocking for low vac signal. the usual fix is a higher stall converter so it drives pass the hesitation.
cuda.340,
May 19, 12:38pm
i always thought these coons with the Integra front needed a bit more detailing to set them more apart. they look like someone assembled the plastic kitset but never painted the molding.
bellky,
May 19, 12:39pm
Whatever^.
gunhand,
May 19, 12:45pm
Umm, OK.Show me something else that looks remotely like them!
Its got twin headlights at the front and thats about all I can see as being simalier, theres Mercs about that look closer to mine than that. Be a sad world if we all liked the same thing.
cuda.340,
May 19, 12:54pm
true gunhand, glad i drive mopar. :)
bellky,
May 19, 12:55pm
Same^.
gunhand,
May 19, 12:57pm
Ive had a couple of yank tanks, well not tanks but coupes lol and brother had a 65 Plymouth Belvadere 440, Man was that a guzzler LOL. Went very well for a big car to.
freeman42,
May 19, 4:23pm
my68 escort van 450871445
hijacka,
May 19, 4:37pm
I would post pics of mine but i don't want to put all of you to shame.
jmma,
May 19, 4:40pm
Checked your profile pic, its a dog (o:
hijacka,
May 19, 4:41pm
Thats old pic, I have 2 amstaffs now. Dog in pics is all grown up hes a big boy now;)
clark20,
May 19, 5:14pm
Pap had a 300ZX, what happened to him!
