Hi, What would cause a car to stall when slowing.
shells80, May 23, 1:54pm
Its a manual 1990 nissan navara ute. Done it to me twice in the past month, then comes right. It does it regardless of weather Im in gear or not, slowing to a stop or taking a corner. I let it rest then drove again and it was fine, so maybe only when it heats up!
pettal, May 23, 1:56pm
does it do it when it is real cold outside! .
pettal, May 23, 1:57pm
petrol or diesel !.
shells80, May 23, 1:58pm
It had warmed up considerably by then so no. Went fine in the freezing cold this morn lol.
Petrol.
shells80, May 23, 2:00pm
I was thinking maybe it was something electrical that cuts out when it heats up, that cuts out. Like the coil!
bellky, May 23, 2:01pm
Fuel filter!
pettal, May 23, 2:03pm
have struck a problem in a couple of nissan utes where the carb freezes up while driving and you have to pull over and let it idle for 30 seconds and away you gogood as gold after that .
shells80, May 23, 2:04pm
True that, does seem to idle a bit funny at times, sometimes high sometimes low. And I thought maybe jets might be blocked!
shells80, May 23, 2:05pm
But I will try that pettal, thanks for that.
hamishcookie, May 23, 2:05pm
If its carburetor then weak float valve would be where I would look.
shells80, May 23, 2:06pm
Yes I was told to check the fuel filter too, cheers belky.
shells80, May 23, 2:07pm
Yes it is carbie.
gtxonp, May 23, 2:17pm
vacumn hoses check for air leaks
shells80, May 23, 2:21pm
K gtxonp, will do.
