5.0L v8 fairmont wont idle when cold
v8cougar, Jul 5, 3:55pm
just got a fuel injected 5L v8 falcon and it wont idle when cold, what causes this problem! any help would be great
fordguy17, Jul 5, 3:59pm
The IAC valve might need a cleanout. It's bolted to the side of the throttle body and they get gummed up with carbon. Take it off and give it a good spray out with brake cleaner. Also, what is your idle rpm usually! Should be about 800-900 rpm if an automatic.
v8cougar, Jul 5, 5:43pm
yeah idle is around 8-900ish, idles very ruff and then stops completely, will clean the IAC valve tomorrow and see if that helps, cheers
fordguy17, Sep 5, 10:15pm
also: www.fordmods.com post up a question in the v8 section, very helpful,
