Infrasun Kero workshop heater
flashgordon_nz, Jun 30, 11:32am
Do they run fine on diesel instead of Kero!
mugenb20b, Jun 30, 12:45pm
I can't see why not, as the only difference between the two is cetane rating.
easygoer, Jun 30, 2:54pm
Check the name plate, generally they indicate the pump pressure setting for the fuel, if there is no setting for diesel then it most likely won't be able to be re tuned for it
