The reading is 1-01-1997. It's a 2003 Holden Astra.
noswalg,
Jun 16, 12:15pm
yep it's definitely wrong. It should read 16-06-2012, hope this helps
ralphdog1,
Jun 16, 12:15pm
Is there a flux capacitor in the back!
ceebee2,
Jun 16, 2:32pm
ROFL!
gunhand,
Jun 16, 2:45pm
Its been "clocked" by the sound of it. I take you do not know how to change it!
tim41,
Jun 16, 2:47pm
my god,what does the time read
trogedon,
Jun 16, 3:01pm
Who cares as long as the time is right or get yourself a good watch.
icemans1,
Jun 16, 3:08pm
maybe it's a time machine
ema1,
Jun 16, 3:14pm
I have an idea the clock is set by RDSvia the factory radio in those, if it has had an audio upgrade it's possible the auto time/date function is not functioning any more! Or it's possible the decoder in the factory audio is on the "Fritz"! That's the case with American = RDBS and Euro = RDS spec vehicles .a.la. Opel/Vauxhall Astra! Other than that I'm not sure on that one. Radio Data service =RDS . RDS is transmitted in NZ by the way. FM radio stationI.D. etc is proof of that.
kokako14,
Jun 17, 8:09am
the Y2K bug might have got into the clock and turned it back into the last century. Might not work with a year over 1999
hi-ling,
Jun 17, 9:21am
If its a standard triple info display, then: Turn on the ignition and switch the radio off, then press top button on right side of display for about 2-3 seconds, then day starts flashing, press the bottom button till the day is correct, press the top button again and month will flash, press the bottom button till month is correct, then press the top button again till year flashes, the press bottom button till the year is correct, continue this thru the time ect. the after setting time repress top button and clock will start from zero seconds. Hope that helps
ozz1,
Jun 17, 12:45pm
behappy.you are6 yearsyounger.until .you ask for the super fund.
trogedon,
Jun 17, 1:57pm
Pull the batter lead off at 12.00 and then bung it back on again a secondor two later. Whoa - its on the correct time.
