Honda civic 91. I turn the car on and let it run, then shortly it just cuts out. Any ideas please.: (
pettal,
Jul 23, 2:23pm
out of petrol .
jae9,
Jul 23, 2:27pm
petrol fine, oil fine' I turn the key, it runs the radio goes, windows goes, then it just cuts out. and nothing.
I can turn it on again and it runs well, then 2 minutes later it cuts out.
jae9,
Jul 23, 3:52pm
is that easy for me (female) to do.can I youtube it.
taipan4,
Jul 23, 3:55pm
some cars have ballast resistor or relay to give more power on starting could be a fault here, although this car may be too "modern"
jae9,
Jul 23, 4:00pm
ok utube that too.
unbeatabull,
Jul 23, 4:09pm
I'd tend to agree with TRH, especially if it's a distributor ignition engine which I would imagine it would be of that year, as Honda's are absolutely shocking for burning out the igniter/module inside the Dizzy.
Hard to tell without actually looking & testing it though
jae9,
Jul 23, 4:14pm
ok, husband home auto choke, we put crc over the colouredfuse box by the battery. turned key it ran, then conked out then hissing noise came out. BUT prior to that when turn the key on and the car ran it gave a burst of power, then went low then.
sounds like cancer
splinter67,
Jul 23, 4:34pm
Get a mechanic to look at it
jae9,
Jul 23, 4:52pm
there is a short around the ignition control module. it seems to be shorting
ok electrical we can't do, mechanic needed.
jae9,
Jul 23, 4:53pm
before it cuts out we can hear, like a shorting/ crackling/ticking sound, maybe shorting. dammit
splinter67,
Jul 23, 4:54pm
go to an auto electrician that's where the mechanic will send you
jae9,
Jul 23, 4:55pm
big thanks
jae9,
Jul 23, 4:56pm
yep, nah nah yea, ratz
jae9,
Jul 23, 4:57pm
auto electrician
motorboy2011,
Jul 23, 5:14pm
My prelude used to do the same, faulty ignition switch.
wotz_it_2_ya,
Jul 23, 5:39pm
Isn't that the Honda dry joint in the ignition relay - no power to the fuel pump. When you turn the key listen carefully. Should be 2 small clicks. Only 1 means fuel relay not tripped. Give the dash a good bash underneath and try again.
peekaboo4u2,
Jul 23, 6:05pm
here's a link about the main ignition relay. don't think the carb version have these though but if your cars injected then that's where id be checking too. good luck
Honda were among the first to get rid of ballast resistors in the early 80's. No Civic from '91 will have one.
If the car is carburettored, especially if it is twin carb, I would check for faulty fuel cutoff solenoid.
motorboy2011,
Jul 23, 7:09pm
thats another fault they are bad for, fuel pump relay, the big brown one on the steering column. My other honda had that prob lol!
snoopy221,
Jul 23, 7:13pm
YIP
elv,
Jul 23, 7:21pm
+2
Or the fuel pump
motorboy2011,
Jul 23, 7:33pm
From what I have heard though, that brown relay causes hard re-starts, rather than making the car stop while running. Mine was especially bad trying to re-start after filling up after getting petrol. Hitting all the solder joins inside the relay sorted it on mine, even though the joins looked fine anyway
jae9,
Jul 23, 7:39pm
don't think its Fuel pump because the light is showing up on the dash
jae9,
Jul 23, 7:40pm
car is not carburettored, it is fuel injected.(auto)
