Yes - usually, but most cars these days don't have "fanbelts" as such, and with modern belts, chances are the belt is stuffed - not just loose - and if it's {over} tightened by somebody who doesn't know what they're doing, it can cause $$$ damage.If this seems a bit obscure, take it to a mechanic.
pretty.girl,
Aug 23, 7:27pm
Thank you mm12345, jmma it is a mitzi chariot (96 I think)
jmma,
Aug 23, 7:56pm
OK, should be easy, just need to check condition of belt, if OK just tighten. Local garage should be able to do it while you wait.
