Nope but the normal stuff will be needed Peddlebox,centre console. driveshaft,clutch plumbing. etc
granada,
Aug 18, 4:33pm
Why would you bother, just sell the auto and buy a manual one. Lot less hassle
00quattro00,
Aug 18, 4:39pm
He may well have a stuffed auto and a manual conversion is cheaper than a recon auto.
Its an easy conversion, everything is just a simple bolt in. Will just need to tell the ecu that is manaul
headcat,
Aug 18, 4:46pm
Does this take into account the loss in value due to having been hashed about!
00quattro00,
Aug 18, 4:54pm
wtf are you on about! you unbolt auto parts and bolt in manual parts, would make it worth more being manual
trogedon,
Aug 18, 4:55pm
If a proper job is done it won't be "hashed about". I've thought it would be a good conversion to do on a Golf stationwagon.
modie61,
Aug 18, 5:39pm
The situation is this,i have seen a car that has a shagged auto,its rego on hold. The idea is to make a clubcar out of it,so it will be converted,not a hash job,but then will surely be thrashed,the car is very cheap to buy. Has anyone actually done this job ! My query is around the flywheel and ecu areas. I was on a usa forum before and they advise against doing it on labour costs,i can do it all myself,so no labour costs to worry about.
thejazzpianoma,
Aug 18, 5:40pm
quattro sounds like he is on the money, the ecu was my concern which he has covered off. I would suggest checking the VW forum's as someone may have even done a guide on this, you never know.
Best of luck, the manual transmission is a lovely unit in those with a nice feel to it.
thejazzpianoma,
Aug 18, 5:42pm
Snap, you posted this while I was writing. Sounds like you have already checked the forums. The VW Place (Platinum something!) in Rotorua if its still going might be worth a call, that's the sort of outfit that has bound to have done one and may be happy to supply parts and advice.
modie61,
Aug 18, 5:56pm
Thanks jazz.
00quattro00,
Aug 18, 6:00pm
You will want a single mass flywheel and vr6 clutch kit, also if its going to be a club car put an lsd in it. for the ecu its just a matter of plugging in vcds and changing it to manual code
modie61,
Aug 18, 6:04pm
Does the mk4 manual have a dual mass flywheel or single !
00quattro00,
Aug 18, 6:05pm
dual, you can get single mass from a 16v mk3 gti
modie61,
Aug 18, 6:08pm
Oh ok,have you done one quattro !
00quattro00,
Aug 18, 6:11pm
Not exactly, but have stripped a few to use in mk2's, currently fitting a 1.8t into my mk2 jetta, I could do the conversion for you seeing as you are not too far away
modie61,
Aug 18, 6:13pm
Thanks for the offer,but would enjoy doing it myself,its half the fun of the whole thing.
trogedon,
Aug 19, 5:21am
"the pleasing aroma is half the point"
Aug 19, 6:07am
most run a dualmass flywheel so you will need to buy a solid mass from uk or there likes
