Is there anyway you can see if your car odometer has been wound back! When I look at it none of the numbers line up. Thanks
morrisman1,
Sep 3, 2:19pm
that can happen to anything.
I look for: ~ broken clips, burred/missing screws needing to be tampered with to remove the speedo cluster. ~ Abnormal wear patterns, eg worn brake pedal on a car with only 60,000km. Same with upholstery and steering wheel. ~ Other things that may give away the milage, eg cambelt next due at 190,000km sticker when car only has 60,000km on it ~ Carjam report, study the milage records for any inconsistencies in the recorded milages (remember that WOF inspectors can mis-type the numbers so take that into consideration if there are odd numbers, also remember that these records are only for when the car has been in NZ) ~ Are any of the digits on the odometer scratched from something like a pick or screwdriver!
Ultimately its the condition of the car that matters, milage is just an indicator of what to expect and not necessarily what the actual car condition is.
nzman89,
Sep 3, 2:23pm
Thanks Morrisman1 that was a huge help!
