Central Locking - What did I miss?
cory_pearson, Sep 16, 11:00am
I replaced the interior handle for the drivers door in my 96 Accent yestaerday.Now when I try turn the key to unlock the door, the little rod comes up, but doesn't actually unlock the door.
Did I miss something really simpole, or are the central locking kits in those Hyundais a bit iffy!
mugenb20b, Sep 16, 11:04am
Did you hook up all the linkages back together!
cory_pearson, Sep 16, 3:17pm
I have.It seems to be touch and go.Works fine the first couple of unlocks then just stops working properly.It has happened before, but on isolated occasions before I replaced the door handle.
Will keep working on it in the meantime - something mustn't be lining up properly.
hondalova, Sep 16, 8:30pm
had same issue with a customers hyundai wen i replaced the handle. i just put a slight more of a bend in the locking rod.
cory_pearson, Sep 17, 12:42pm
I'll give that a go tonight.Cheers
ceebee2, Sep 17, 2:43pm
Suggests something is jamming it since you replaced the door.
cory_pearson, Sep 23, 6:21am
Took the car in for a warrant and to get the door looked at.Looks like the solenoid in that door lock is stuffed.The mechanic did something so that I can unlock with my key and need to hold the rod upwhen unlocking from the inside.I am going to get it replaced - probably at the same time get some kind of car alarm installed.
Thanks again for the advice and suggestions guys.I appreciate it.
intrade, Sep 23, 6:26am
inspect all ok then do what he said its what i would do but not to mutch otherwise it might jamm somewhere and try with the cover off the door first.
