WOF. If i have taken car for awof and it failedbecause garage too padantic but will cost 400 bucks can i take car to other garag
toysky,
Nov 12, 8:24am
If I HAVE TAKEN CAR FOR AWOF AND IT FAILEDBECAUSE GARAGE TOO PADANTIC BUT WILL COST 400 BUCKS CAN I TAKE CAR TO OTHER GARAGE TO ATTEMPT AGAIN! in this case its power steer hose , Icann;t see leakcheers
Nov 12, 8:27am
Power steering fluid is leaking. Sorry but how is that being pedantic! If its only a tiny bit of fluid -seepage rather than a leakmaybee if you completely wash the entire area it may pass
unbeatabull,
Nov 12, 8:30am
A P/S leak can be pretty major. You could just clean all the lines, rack etc and try another station, but it's not really fixing the problem.
mrfxit,
Nov 12, 8:38am
True but if it IS a leak & not just spilt fluid of some sort, then it will show clearly if it IS or NOT
mopsy3,
Nov 12, 8:41am
It's leaking/seeping. Fix it so we are all safe when you are on the road.
lyonruge,
Nov 12, 8:41am
To answer the question, yes you can. But it would be better to clean and check, if it leaking, even a small leak is an indication of a weakened hose which may blow comletely at any time. Just fix it.
toysky,
Nov 12, 8:52am
OKOKI;LL FIX IT THOUGH I CANN;T REALLY SEE FAULT
CHEERS
lyonruge,
Nov 12, 9:25am
No, it only tells the issuing agent when and the last check was and what it failed on, doesnt even show up until a pass has been entered. Dumb eh!
davidgb,
Nov 12, 10:22am
clean it, get wof and and fix it soon!
mm12345,
Nov 12, 11:02am
Not if you don't buy a vastly over-priced OEM PS hose.Take it off, take it to Enzed or other hydraulic hose specialist, get them to fix it, fit it, and top up PS fluid.Shouldn't cost you more than about $150.
toysky,
Nov 12, 1:57pm
Yes the above is whats goin to happenprice they gave was for a nissan part, I saw hole pin size
stevo2,
Feb 21, 5:59am
yeah I know how you feel. Took my car to the Testing Station but failed. They said it was unsafe cause it had bald tyres. Perhaps I should take it to a different garage who might not notice!
