Car only turns over after 20 times turning key on
neryl1, Dec 6, 8:34pm
just clicks otherwise had starter motor checked doesnt work any better with jumper leads should i still clean battery terminals to make sure. Its auto and theres a click by the lever that changes gear sometimes is there an earth to the auto transmission to check somewhere. turns over better after its been driven and started straight away 3rd turn of key and then 1st turn of key.
skin1235, Dec 6, 8:37pm
in a honda thats perfectly normal, but in your rolls royce then theres something not quite right
skin1235, Dec 6, 8:39pm
but hey, some idea of make and model may help
it does sound like whoever checked the starter motor needs checking too
or does it actually try to wind over if you jiggle the gear stick - what happens if you put it in N before trying
neryl1, Dec 6, 8:44pm
92 subaru legacy took starter out and got new contacts in the starter motor and was working in the shop.
gadgit3, Dec 6, 8:46pm
Starter contacts or solenoid. These earth through the earth brush of the starter motor so it could be worn earth brushs
neryl1, Dec 6, 8:47pm
no no different wiggling auto gear lever or in neutral but i used to move the lever and thought it worked after that but now that doesnt work better that was when it turned over at 6th turn of the key its got worse. when it winds over it turns over and starts well but doesnt turn over at all sometimes
rob_man, Dec 6, 8:48pm
Yesssssssss. Twisty pointy finger thing.
snoopy221, Dec 6, 8:51pm
Could still be a faulty solenoid in the starter working okay on a warm day when contacts fitted.
Suggest you refer problem back to the shop that did the starter motor contacts- preferably leave them the car overnight so they can see the problem when it is present on first start cold
edited to add could be worn brushes also - starter may not have been stripped fully when contacts done.
skin1235, Dec 6, 8:52pm
check the earth strap from the engine back to the battery or to a body part, make sure it is tight and has good contact
clip one of your jumperleads to the battery neg and the engine
neryl1, Dec 6, 8:52pm
what about where it has to be in park to turn over an auto where other cars will turn over in gear
snoopy221, Dec 6, 8:54pm
Incedentaly how many kilometres has the !roo! done.
splinter67, Dec 7, 6:50am
Could also be the ignition switch had to replace one in a 96 same faults
neryl1, Dec 9, 7:03am
anyone know if the car wont turn over if the earth wire to the fuel pump is loose the fuel pump does a weres noise when turn key on havnt seen where it is drivers side by the wheel sounds like.
gammelvind, Dec 9, 7:08am
Tired battery, try replacing the battery rather than using jumper leads.
kevymtnz, Dec 9, 7:11am
either gear stick switch or ignition
neryl1, Dec 9, 7:11am
put a better one in cleaned connections + one doesnt look that good smoth wise but i think its ok
neryl1, Dec 9, 7:14am
im thinking gear stick switch if i remove the plastic centre stuff by the handbrake gear stick i should find it somewhere!
therafter1, Dec 9, 7:17am
Before you get carried away try Splinters post at # 12 as it can be a common fault. Instead of quickly turning the key to the start position, turn it very slowly as the key barrel can be worn and it is possibly turning past the contact points in the switch.
skin1235, Dec 9, 7:24am
you'd need a suby owner who knows where the inhibitor switch is, some are on the box, some are on the shift, it's not unknown for then to stuff out
easi way to check is get a short piece of wire and bridge the battery connection and the solenoid connection at the starter motor, if it tries hard every time you bridge it ( leave ignition turned off) then the issue is in one of the switches, either ignition key or inhibitor
make sure you have the ignition turned off - if you're head down under the bonnet and it starts, and is in gear, it's either going to try to run you over or run away from you
skin1235, Dec 9, 7:26am
although your first post says it clicks - that indicates the solenoid is actually pulling in, and it cannot do that if you have a faulty switch
clicking indicates an issue in the starter, either it has poor battery, or poor connectiions or the dude that fixed it needs a rocket
