Car aerial plug
leanne_6, Dec 13, 4:57pm
hi guys, the aerial plug has broken, so where can i find just the plug! thanks
theram1, Dec 13, 5:19pm
Male or female. Soldered or screw on type.
edangus, Dec 13, 5:28pm
Dick Smith - the bigger stores
leanne_6, Dec 13, 7:17pm
Male, screw on would be better, ill go to dicksmith tomorrow. thanks
theram1, Dec 13, 7:28pm
is the broken one screw on, not all are, some are soldered.
leanne_6, Dec 13, 8:02pm
it looks to be soldered on
theram1, Dec 13, 8:12pm
You can try reconnect it, but it can be tricky: your antenna uses a coaxial cable, with a centre conductor surrounded by a shield. Each has to be re-connected properly and kept separate from each other. They connections need to be soldered.
I have had a car that had an extension to the lead, check for one.
leanne_6, Dec 13, 8:22pm
ok cool thanks i think ill give this a go
leanne_6, Dec 13, 8:26pm
icemans1, Dec 13, 10:19pm
good post
kamitchell, Dec 14, 6:18am
If it's the plug that's broken it won't work but this will
http://www.jaycar.com.au/productView.asp!ID=PP2044
leanne_6, Dec 14, 9:55am
sorry i am going to follow the steps andrea_w provided, i have the cord with plug i just need to connect the 2 wires together
