02 ford transit clutch ?
toyboy3, Dec 13, 7:37pm
any easy way to remove the gearboxwithoutremoving the crossmember !
tiny15, Dec 13, 7:43pm
gas axe
panelvanner, Dec 13, 10:44pm
Pull the gearbox back and sit it on top of the cross member, not a whole lot of access room but can be done.
dr.doolittle, Dec 14, 5:45am
Pay someone else to do the job
the-lada-dude, Dec 14, 5:51am
CUTTING TORCH !
intrade, Dec 14, 6:06am
you cant use a gas axe sometimes you can do a clutch without fully removeing the gearbox like i done on australian camry toyota. Another one like them friggen isuzu with welded crossmember i had to reassemble the clutch thru the hole of the clutch leaver , Like hell was i going to remove the front axle so i could lift the engine up and forwardto get the 1 inch space that stopped me removing the gearbox.
Be happy if you can remove the crossmember .
