Anyone reupholstered their car
kelzzz, Mar 12, 6:19pm
themselves! I can sew, no problem. I can take shit apart, no problem. But what about glueing! I don'twant them all saggy, ya know! I'm thinking sewing a whole piece, and fitting like a seat cover. Any tips!
a.woodrow, Mar 12, 6:32pm
take the old covers off, unpic all the stitching and use the pieces for your patterns
quickstitch, Mar 12, 6:35pm
i've done all my own cars with great success, but then i am a trimmer by trade. I have seen furniture upholsterers make very average results in car trimming.tip for you, pay to get it done. It is not the sort of thing you can pick up overnight but if you are dead set on doing it then heres a few tips.Before you unpick the old seat cover for a pattern, put check marks on all joins and transfer them onto your new pieces of material to use as line up marks for when you sew it back together. Cut every panel out of the fabric in the same direction. if you cut one out wrong and it gets sewn into the seat it will look like a different fabric.
quickstitch, Mar 12, 6:39pm
you will need hog rings and hog ring pliers, plus more than likely spray glue, you can use aerosol cans, 10 mm trico backed foam, listing tape. Plus most domestic sewing machine will struggle to sew a few layers of heavier fabric.
pollymay, Mar 12, 6:51pm
Yes, it turned out pretty ok. The old interior was shagged so had nothing to lose. Some pics of the kinda things I did. It's NOT easy, I used a tonne of contact adhesive and had to do foam repairs along the way.
http://i536.photobucket.com/albums/ff323/328FTW/Holden%20SS/001.jpg http://i536.photobucket.com/albums/ff323/328FTW/Holden%20SS/009.jpg
http://i536.photobucket.com/albums/ff323/328FTW/Holden%20SS/019.jpg http://i536.photobucket.com/albums/ff323/328FTW/Holden%20SS/021-1.jpg
http://i536.photobucket.com/albums/ff323/328FTW/Holden%20SS/007-2.jpg http://i536.photobucket.com/albums/ff323/328FTW/Holden%20SS/010-3.jpg
Hog rings are a must. How it works is you basically fit the fabric to the topside you see using set in wires in the foam to hold it down tight then stretch it around the sides and clip in with the hogrings underneath. if you do it wrong there are wrinkles everywhere. Mine settled in with some light working and was pretty smooth all over.
What kind of fabrics you want to use! Because a piece of genuine suede is a lot different to vinyl or denim etc. Some stretch nice, others don't. Depending on the thickness you have to think carefully about seams as well, you get 5 stacks of something thick it's going to be a nightmare.
kelzzz, Mar 12, 7:00pm
Thanks for the tips quickstitch. I can design and make clothing so surely upholstery can't be too far removed haha.
Great work pollymay, they look amazing! I see what you mean about the wrinkling. I won't be using vinyl, just regular fabric. Will have to do some research on hog rings.
kelzzz, Mar 12, 7:01pm
Are you best to get something with a bit of stretchh or not!
pollymay, Mar 12, 7:50pm
Car upholstery normally has stretch in one direction to help fit it. I found it easier with the direction with stretch than the one without
socram, Mar 13, 1:11pm
I acquired an industrial sewing machine, but have had problems setting up, with the type of thread supplied (supposed to be OK, but wasn't) and also the correct needles, sewing a mix of suede, leather and vinyl with the backings.Given it a break at the moment and might need the sewing mechanic back - yet again!
kelzzz, Mar 13, 4:46pm
The main problem I'm having is finding upholstery I like! Have been all over town and have an idea in my head of what I want but can't find it. I did one door trim today in what I thought would be nice but it's just not dramatic enough. It stuck well tho with spray glue and duct tape :p
kelzzz, Mar 13, 4:48pm
yikes! You're braver than me, I'll stick to normal fabric I think
neville48, Mar 14, 12:41pm
When you have finished with yur glue and duck tape and she's all done at least yur safe in the knowledge that there will still be an upholsterer just down the road who can fix it properly for you, thats why he's there.-
.waiting
trogedon, Mar 14, 1:46pm
Tint the windows. If you muck up then less of it can be seen from outside. Is that a bit negative.
Nice joy Polly.
kelzzz, Mar 14, 5:16pm
not sure what you're trying to say but I don't attempt something unless I know i will do a proper job of it.
jmma, Mar 14, 5:22pm
Polly did a nice JOB as well(o:
trogedon, Mar 15, 4:47am
Got me.
