Hi, its in the boot, getting at the motors ok but is there sum kind of special tool to undo the aerial tself? its stopped goin up & down , just stays up but i can hear the motor working, hoping to get a replacement, Thanx
bigfatmat1,
Dec 15, 7:37pm
You undo the nut on top carefully on top trying not to slip and damage it or gaurd. Then turn radio on and pull mast out and hope cord comes out with it if not you will need to remove aerial dismantle remove cord reassemble fit back to car turn radio on and feed new aerial into it. Some ford's use a stupid plastic shroud wich can be a mongol to remove
crtnz,
Dec 16, 11:00am
mongol ?! mongrel ?
bigfatmat1,
Dec 16, 1:42pm
#autocorrect
lusty9,
Dec 16, 8:47pm
Don't even bother, take it in to get done. I had one of these dinosaurs back in 2002, tried taking the dang aerial out and ended up with the whole front guard off, put it back on and it wouldn't sit properly.
holdensorfords,
Dec 17, 4:24am
That would have been a mission all right. Taking the whole front guard off to get the aerial in the boot out. Pays to read post first.
bigfatmat1,
Jun 8, 7:07pm
I believe he possibly had the ute which has the aerial in the front
