Daihatsu Charade 2005,no adjustment on bulkhead,done at fork end,or pedal? TIA.
frank1,
Apr 1, 2:24pm
Whoops,should have said cable operated
bjmh,
Apr 1, 3:28pm
have a look where the cable goes onto the gearbox fork,usually a 6 mm nut and maybe a knurled knob
Apr 1, 3:41pm
follow the cable up. Usually part way up theres an adjuster
ml6989,
Apr 1, 9:05pm
It may have a circlip and a series of slots for the clip where the cable passes through the bulkhead. I can remember adjusting one like that many years ago but can not remember if it was a Diahatsu or a Daimler!
ceebee2,
Apr 3, 1:26pm
I know the pre- 2000 adjustment was the circlip on the cable at the firewall but not sure of post 2000. (12-15mm when you pull on the cable)
frank1,
Apr 3, 1:49pm
Looks like only adjustment is on fork.
ceebee2,
Mar 31, 5:09pm
Simply adjust with approx. 20mm freeboard, test with foot to ensure the clutch doesn't disengage too close to the floor.
