our 2001 318i bmw prob needs anew motor? ran out of water and think motor has seized? any backyard mechanics out there willing to give it a go?
elect70,
Mar 6, 1:26pm
If you cooked it shes rooted will have warped the head at least . buy used motor & get mech to help you fit it
poppajn,
Mar 6, 6:53pm
Scrap it, a motor will cost more than it's worth
Mar 6, 7:08pm
might also have to fix the reason why the engine ran out of water. along the way . do you know why it ran dry? also why would it seeze if it still had oil?
katee29,
Jun 15, 9:27pm
ok so maybe not seized but wouldnt it have a cracked head or something now if it ran out of water and made terrible noises and blew out steam?
thejazzpianoma,
Jun 16, 4:36am
It's quite possible the motor is toast, but not a given. The first step IMO would be to give the engine a quick compression and leakdown test before writing it off.
What exactly did these "terrible noises" sound like?
Where did it "blow out" the steam, from the exhaust or engine area?
Does the motor crank/start now? (If it starts only run it for a few seconds with no water in it)
elect70,
Jun 16, 12:07pm
If its alloy block & head dont even bother just replace engine if want to keep the car . overheating roots them ,need severe head & block skim & never the same & way too expensive to recon compared to cars worth
msigg,
Jun 16, 3:34pm
Yes elect70 is on to it, get a second hand engine from a smashed car some cheap labour to fit, or sell the whole car for parts. Not worth mucking around with.
sticky232,
Jun 16, 3:58pm
Scrap lt my son had one took to mechanics over 4,000 worth to fix never right each time he took back something else was wrong
tamarillo,
Jun 16, 4:00pm
Might help if you told us where you are? Someone in auckland won't be much help if you're in Invercargill! I can advice if you're in Nelson! Euro workshop here wrecks them. As others said you might be lucky and get away with head gasket only but not if it is seized.
jmma,
Jun 16, 4:03pm
Probably Christchurch. Google told me to look at his profile Lol (o:
tamarillo,
Jun 16, 4:04pm
yes you're right, just kinda feel we shouldn't need to look at profiles if someone wants help that is geographically inclined. But I'll remember to ask Google next time!
pandai,
Jun 16, 4:12pm
I'd go and ask the boys at Eurorec what they can do
jason_247,
Jun 16, 4:36pm
if its 2001 its likely a n42b18 engine which is a hateful piece of crap. very prone to cooling issues, valve train issues and burning oil.
Bmws are very prone to plastics in the cooling system failing so along with a new engine i would be looking at replacing the radiator, hoses, expansion tank and waterpump/thermostat as its routine maintanence with these engines. bet on $600-$1000 for these parts depending on your hookups
tamarillo,
Jun 16, 8:27pm
Op, you need to get it diagnosed and learn the extent of the damage first. If you find a cowboy to have a go they might waste time and money doing wrong things.
bobthebuilderb,
Jun 20, 5:01pm
I'm in christchurch
bobthebuilderb,
Jun 20, 5:01pm
I'm in Christchurch.thanks everyone for all the advice.
kdcentralni,
Jun 22, 7:42am
Worth more in parts now seat occupancy sensors, shocks, seat trim, etc.
petermcg,
Jun 22, 10:45am
Just be sure to diagnose the problem correctly, If the engine run out of water possibly overheated and seized from being to hot, there is a good chance that it will run agin when it cools down as it will only get tight while it is still to hot. If it runs again, do a check on comressions and also for leaking head gasket and or crack, The headgasket should not be blown just because the motor got hot, it is the other way round, a blown headgasket will generally create a symptom the will make the engine get hot. If it has no comression it is the rings, so if the head gasket is still ok, I would not remove the head. Simply remove the engine and remove crank and pistons from the underside of the engine, replace the rings for a couple of hundred dollars, and off course remedy where you are loosing the water from.
bobthebuilderb,
Jun 22, 4:32pm
so roughly what would you think its worth for parts?
elect70,
Jun 23, 1:39pm
^^^ there is a similar 1 on TM in Ch ch , rolling
tamarillo,
Jun 24, 7:18am
depends on how good car is and what options it has like leather seats. But wrecker I know never pays more than grand normally 500. Ouch.
thunderbolt,
Jun 24, 7:34am
Any chance you could make a video showing this gold nugget of advice in action? Close ups of how you remove and refit pistons with new rings through the bottom of the block would be very helpfull.
anenigma,
Jan 28, 1:19pm
Shame you in Chch Bob - a mate would buy that now
