Prediction time!
Page 3 / 4
ema1, Aug 5, 12:08am
Waiting for a veiled B/S biased answer !
snoopy221, Aug 5, 12:08am
ema1, Aug 5, 1:01am
Ha ha ha . yep.
How's it goin me ole Snoops.
john1623, Aug 5, 1:22am
Dont you guys know all cars are great when they are going but shitboxes when they break down.
thejazzpianoma, Aug 5, 1:33am
Somehow I don't think you do.
thejazzpianoma, Aug 5, 1:35am
Actually the proper warranty companies in other countries where there is actual competition charge based on the actual reliability of the vehicle. Hence the reliabilityindex.com which is based on the data the largest of such companies in Europe uses.
The few companies that offer warranty's in NZ are pretty much-glorified scams. That aside, you are off topic.
snoopy221, Aug 5, 1:35am
snoopy221 wrote:
Here we go does this mean some
Actual Facts are coming?
* The word of the specialst rebuilder who only rebuilds these transmissions and who has showed me the various failures, explained when they fail, how and why etc
! And a lill gurl STILL Waits!
Reposted in case ya missed it
thejazzpianoma, Aug 5, 1:39am
What exactly are you looking for snoopy?
The rebuilder also gave a figure of about 120K as average life span without being prompted. He of all people should know given he records the km data on exchange units etc.
ema1, Aug 5, 1:59am
You think what you like. as usual,but I know better !
thejazzpianoma, Aug 5, 2:00am
Ahh right. Well I was surprised to find out that there is not just one or two issues. It seems to be more that the transmission is built from the ground up to be limited life. Issues range from surface and bearing type mechanical issues through to the internally mounted electrics. Rather than do my best to explain the range of what I have seen (which is difficult without diagrams etc) when I have finished up in the shed I will see if I can find a great article I read about them a while ago for you. It had all the diagrams and explanations nicely laid out.
It's not straight forward like the Aisin 5 speed or early dry clutch DSG where you saw the same couple of issues over and over though.
ema1, Aug 5, 2:05am
Funny how Aisin & Jatco get the negative from you when DSG crap doesn't . more like veiled B/S to cover up their faults, not to mention all the other woes VAG crap has that also gets the cover up treatment by you.
snoopy221, Aug 5, 2:08am
Oh Do Behave
Nissan has had that issue for bloody YEARS way before the Renault Nissan aliance
Hell the amount or skyline and nissan diesel transmissions that the temperature controller inside the trans that goosed as it couldn't handle being in the hot trans fluid and had to simply be bypassed with a resistor or replaced. [resistor was so simple and five min jobbie compared to repacement]
Which caused them to drop top gear/overdrive -as they were supposed to not engage it cold.
Is this were we add the old HQ and the GM Tri matic which had the plastic accumulator valve which AGAIN could not handle trans fluid temp and failed? /
[Causing hell thump shift]
And ema probably like me has done fkn more of those plastic valves than ya've had hot moisties.
LOL
Se there are 2 SPECIFICS.
Shall i check google?
mmkay KNOWN problems took seconds
https://www.google.co.nz/search?q=HQ+and+the+GM+Tri+matic+which+had+the+plastic+accumulator+valve&rlz=1C1CHBF_enNZ807NZ807&oq=HQ+and+the+GM+Tri+matic+which+had+the+plastic+accumulator+valve&aqs=chrome. 69i57j69i59&sourceid=chrome&ie=UTF-8
http://www.offroadexpress.kiwi/Forums/viewtopic.php?t=23416
ema1, Aug 5, 2:09am
It's my betting snoops that . it will get neatly side stepped . AGAIN, those questions and other questions requesting explanation or proof have been asked many times previously . but often no explanation is forth coming pretty much that I have seen.
Jazz often asks for proof etc of folks on here, but dismisses what he hears as it doesn't suit his agenda . but in return he rarely gives any when asked. often because it's fake or worse . LIES. agenda based propaganda !
ema1, Aug 5, 2:10am
"Prediction Time". now that is Crystal Ball Gazing stuff for sure ?
thejazzpianoma, Aug 5, 2:10am
Yes, go and google
thejazzpianoma, Aug 5, 2:11am
For someone with so many better things to do you sure seem to be posting a lot.
snoopy221, Aug 5, 2:14am
After posting.
As i Do know what i am posting about from HANDS-ON EXPERIENCE
curlcrown, Aug 5, 2:15am
What country were you referring to when you started this post?
ema1, Aug 5, 2:15am
Like you always do . oh thou auricle !
That's what I call stealing Google's Thunder !
ema1, Aug 5, 2:16am
Christ man . no where as much as you do. there's a big difference. My posts are credible/factual.!
snoopy221, Aug 5, 2:16am
Ya must have done a few of the old trimatic servo release plastic dump valves in ya GM time ema?
ema1, Aug 5, 2:18am
Answer curlcrown is as usual . Clear as Mud or no answer at all !
ema1, Aug 5, 2:19am
Seen the insides a good number of Trimatics . Powerglides, Turbo Hydramatics etc in my time snoops, but not as many as what seem to require major stuff in more modern stuff , long time ago now though I have to admit.
Pre electronic controlled stuff back them matey.
Thing with a lot of Euro stuff they chop and change designs and "upgrade" etc etc just to confuse the issue . no one with a right mind can be bothered with all the vehicle off the road for all the silly stuff Euro's and odd other makes to a lessor extent have these days, Euro's are a hopeless case when big distances away from service centres . Japanese makes are far better in that domain, always have been. it's called reliability and it counts for big praise in my book.
snoopy221, Aug 5, 2:22am
Yeah rkn it would be yonks ago for you -LOL
Point is it is a specific manufacturers STOOOPID idea of putting a part in an environment where it WILL fail.
And the same claim has been made by jazzz
With NO Facts
snoopy221, Aug 5, 2:25am
"Prediction time!"
