Ford Courier 2001 Rear Wheel Bearings.
greenfox, Dec 26, 2:51am
The above vehicle failed the warrant due to this issue. So I purchased a new set from Repco
https://trademe.tmcdn.co.nz/photoserver/full/1458636528.jpg
I have not started to take the vehicle apart yet. I was wondering where the
star/lock washer in the above kit goes?
mechnificent, Dec 26, 4:27am
I would guess that locks a nut that holds the bearing onto the axle.
mechnificent, Dec 26, 4:28am
Or the axle into the bearing.
franc123, Dec 26, 5:28am
As above, a huge nut is used as a bearing retainer. You will need access to a good hydraulic press to do that job.
intrade, Oct 5, 11:51pm
i guess that's the front then? i only ever had to adjust the bearings on isuzu mu with play . with that star washer bend down tighten re-bend.
if it makes noises or feels like stones are in there then the bearing is a goner.
