My courier was fine before and then I went to start it again and it wont start, only makes a ticking sound, any ideas!
the_chooky,
Mar 27, 3:07pm
Battery.
tigra,
Mar 27, 8:46pm
Or Jammed starter.You could be a bit more descriptive.
40wav,
Sep 1, 4:45am
Check the connection of the battery leads to the battery terminals. They may be oxidised which will make for hard starting. Take them off, clean them up with a wire brush, then rub vasaline or grease all over them and put back on. That will probably fix it. Let us know how you get on.
