Cost of rust repair question
charmed14, May 1, 10:52pm
Need to have rust repair along back window bottom seal.Does anyone know how much this would be for the job or just to have someone take the window out!
intrade, May 1, 11:06pm
depends on how the window comes out . if it is glued in then it be a minimum of 200$ just to remove and refit the window again after.
johnf_456, May 1, 11:08pm
^unless if you have glass cover, there is always that other way
mrfxit, May 1, 11:48pm
Most panel beaters will be able to quote you for the glass remove & refit . BUT . theres no reasonable way of quoting for the rust repair UNTIL the window is out
johnf_456, May 2, 12:28am
Has for quotes most will give you a vague idea. but you do not know what it will look like under the screen.
