my S14 has a bad vibration when the power is on and you turn around a corner or go over a slight hill and the weight comes off the shocks. It only seems to do it with factory suspension but not with adjusties Help i can't work it out i even removed the adjustable camber arms to cure it but no luck so far.
bubbles244,
Oct 10, 6:15pm
wheel bearings or axle cv
vivac,
Oct 10, 7:30pm
Axle tramp.
Dec 24, 4:49pm
OP -think it through. or KISS it. If you only have the issue with factory suspenders what EXACTLY is it that you change!
Sight unseen I'd be looking at the condition of the factory shocks as a start point. From there I'd be looking at angles of components to see what changes and if thats the issue. Then maybee look to see whatthe REAL clearances of components under load/drive is. If you get the car up on a hoist you may see telltale sighns -ie shiney steel or rubber marks where they shouldn't be
