Automatic transmission toyota HELP!
mrrxtrader, Nov 19, 1:58pm
hi there i have a 1996 toyota carib. i have just finished replacing tha engine and now my automatic transmission slips and car will hardly move at all. seems to like reverse more than going forward. trans has new transmission fuild and filter. was working fine before i changed my motor. any help would be much appreciated. cheers!
franc123, Nov 19, 3:20pm
The fluid is at the correct level and the filter was installed correctly!
tassle1, Nov 19, 3:35pm
Have you got the auto change linkage connected correctly!
mrrxtrader, Nov 19, 8:48pm
yes and yes
4piggy, Mar 18, 1:06pm
if trans torque converter came partally out when removing motor and converter wasnt refitted properly in to trans the pump will probably besmashed in trans, common to happen
