Did you know that when approaching another vehicle it is better to slow down and drive closer rather than drive close to the ditch! The stones ricocheting from the wheels would hit higher if the vehicles pass each other 2 metres away than 50 cm away. Going slow would also help. I often see the oncoming vehicle going closer to the ditch and I end up driving closer to them to avoid stones hitting my van windows. Another tip is to drive certain speed to avoid corrugations. If you go too slow then you catch the bottoms and have a rough ride.
richard198,
Nov 23, 8:36pm
Did you know that if you aim for the other driver, they tend to lose their nerve and end up in the ditch rather than you!
pollymay,
Nov 23, 8:40pm
Helps if you go past them sideways making sure to spin the wheels to direct the stones away from them.
gadgetman,
Nov 23, 8:43pm
I aim about 50 cm away from their side. Once I got a bit closer on narrow country road and the other driver used horn. I stopped and had a chat with him explaining this law of physics which he luckily understood. Basic ballistic physics. To avoid rocks hitting your car you need to be either very close or more than 10 metres away. I was told this driving tip myself by my truck driving big brother.
gadgetman,
Nov 23, 8:47pm
That is what some young guys thought afew years ago in Canterbury. They passed me and sprayed gravel into my windscreen causing a crack. I caught with them a kilometer lateas they were stopped for something. Then I pointed at the crack and told they did that.
kevymtnz,
Nov 23, 8:53pm
when passing slow to a reasonable speed as u pass each other dont brake or accelerate even on a tarseal when changing lanes to become in front of someone else is not to continue to accelerate due to loose stones that lay between the lanes mainly for rearwheel drives
LMFAO at a BR this afternoon that puttered out. Got out to fix it & another mate arrived to help & when they got the pos going again, he spun the wheels pretty good JUST as his mate did a U turn right behind him **on loose gravel**. Nearly fell over laughing so hard, watching all the gravel getting sprayed at the mates car
surf_quiksilver,
Nov 23, 9:11pm
You showed them!
dr.doolittle,
Nov 24, 6:30am
"And that's all I can remember".
gadgetman,
Nov 24, 10:35am
There was no further drama, major road rage but just a heated exchange on my part. Those guys were just young and inexperienced, I got the crack fixed at Smith & Smith autoglass later.
kamitchell,
Nov 24, 10:42am
I did lots of gravel rd driving in aussie and was common sense (and a requirement on mining leases) to slow right down passing other vehicles and people so as not to kick up stones and dust.
drog,
Nov 24, 11:04am
There is an obvious flaw in this technique.
bwg11,
Nov 24, 11:55am
Isn't it obvious. If you move over to the left early, the other driver will stay in their shingle tracks and not flick stones at your car if they don't slow down.
rob_man,
Nov 24, 11:56am
I always find the less time spent inside the danger zone the better, it's hard to hit a fast moving target. Go as fast as you can past the other vehicle.
nightboss,
Nov 24, 12:15pm
I thought there was a lot of morons posting on "Opinion and Politics" so I changed to "motoring" and found this. Going back to "O & P", at least the morons there can't play the banjo.
mm12345,
Nov 24, 12:24pm
You're probably right.From what I've seen of that forum, it'd be damned hard to play the banjo when you're trying to keep a finger in each ear, hand over each eye, and lips on your favoured leader's backside.A kick drum's the right instrument - very appropriate really.
richard198,
Nov 24, 3:21pm
It takes a lot longer to get up north.the slow way.
rob_man,
Apr 5, 6:12pm
Shame you stumbled onto one of the tongue in cheek threads without having the wit to recognise it as such, try to remain focused on what you need to do on Saturday. You wouldn't want to forget to vote Labour now would you.
