Have a look there, they are sometimes repairable but best to just get a 2nd hand, can be had cheap enough.
the-lada-dude,
Dec 1, 12:01pm
thats just excellent KINGFISHER21. some of you chaps are sooo good at finding stuff on the net !
crzyhrse,
Dec 1, 12:33pm
Advanced for Ford, Avondale.
bevharris1938,
Dec 1, 2:51pm
And the windows fall off their runners
bob1088,
Dec 1, 2:55pm
we used to either get used from affordable etc or clean contacts that get water in.
unbeatabull,
Dec 1, 8:14pm
Are you sure its the Regulator.
Window no go is common - the cause can be 3 things - Motor faulty, switch faulty, Regulator faulty. Easiest way to start checking is power at the motor (they use a double post throw switch so there is 4 connections, not just power/earth), then if power at motor, remove motor and see if it works, if it works then must be regulator problem.
Quite often if its a motor, a few "taps" with a hammer can fix them.
mellisa2000,
Dec 1, 10:31pm
Very common for switch issues, if it is--pull out, pull apart, clean contacts reassemble. That easy! Fish
the-lada-dude,
Dec 2, 5:51am
ta everyone, the car is due in next week, and to be fore warned is to be well armed.
unbeatabull,
Dec 1, 8:14pm
Quite often if its a motor, a few "taps" with a hammer can fix them. Switches often get dirty contacts, can pull apart and clean with sandpaper/small screwdriver. Regulator - replace it.
