Does anyone have experiance in putting a diff from a falcon wagon/ute into a sedan. My xf sedan diff has blowen and i can get a wagon diff but dont know how difficult it will be to replace the internals.
snoopy221,
Dec 6, 6:09pm
Cobwebs in da spiders aye. Tip-loosen the crown wheel nuts on em BOTH before ya undo the caps and use your crown wheel and the *donor* diff centre with spider gears. just look closely at how your diff centre was shimmed and refit the same. Kapeesh!
302cortina,
Dec 6, 6:30pm
in the past ive had to take the bearing of the pinion shaft and take out a spacer,then refit the bearing.
fordzfly,
May 9, 5:03pm
ok sweet. So can i just change the centres over. Havent had much to do with lsds. Do you have to change the pinions over or only if its a different ratio
