is there any diffrence between the engine mount's on a mk1 through to mk 5 2 litre engines!
phillip.weston,
Dec 10, 5:57pm
given that the production spans some 20 years and two different engine families, then yes they probably are different sizes.
panicky,
Dec 10, 6:19pm
Mk3 was the first to have a 2.0L
robinm1,
Dec 10, 7:16pm
Actuallythe Pinto engine, ie the 2litre engine bolts up ok to the std engine mounts of a 1300 Escort which of course ran the kent motor, the same basic block as the mk1 cortina, so there is a very good chance that the pinto will bolt up ok in a mk1 Cortina. You may have to change the actual mounts to Pinto ones, but it SHOULD all bolt up ok. Not so sure on the gearbox mount though.
brokebloke1,
Dec 10, 7:44pm
sorry to crash the party but will a MK3 cortina pinto motor bolt up to a MK1 capri engine mounts, looking at upgrading the capri
kevymtnz,
Dec 10, 8:04pm
you may have trouble with the sump so a cut in weld here maybe needed
sunny665,
Dec 11, 5:01am
ok, do the mk 3-5 2L cortina's have the same engine mount's , no one achually awnsered my question, i just pulled my mk 5 engine out, and need to know if i can put a mk 3-4 in or not!
brokebloke1,
Dec 11, 5:18am
yes you can I put a mK5 into a MK3 didnt change anything just dropped in
sunny665,
Dec 11, 8:10am
thankyou :)
marte,
Dec 11, 12:34pm
Ford serria engines a upgrade on Mk4 & 5.
rob_man,
Dec 11, 12:37pm
Possibly watch for different sized spigot bearings, that was pretty much the only thing different on some of the early Kent engines.
pfemstn,
Dec 11, 1:03pm
all blocks have a universal mount casting from 105e to mk 5 cortina ie all the straight 4 ,s
